95 EG cluster dimming
Old Jul 18, 2018 | 11:09 AM
dlx111's Avatar
Default 95 EG cluster dimming
My cluster has been going in and out randomly like going from full bright to dim and inbetween. Nothing seems to trigger it ie turn signals, wipers, etc itll just dim then come back. Headlights dont dim when cluster dims, all other electronics are in good shape havent had anything else fade out or stop working so where should I start looking?
Old Jul 19, 2018 | 10:20 AM
Db1_77's Avatar
Default Re: 95 EG cluster dimming
Sounds kind of like you're experiencing the beginning of a failing splice somewhere. Might need to do a little bit of digging along the harness between your dimmer and cluster harness to find the point where it breaks off to the climate control area.
Old Jul 20, 2018 | 09:41 AM
Relic1's Avatar
does the heat/fan controls dim when the cluster dims?
yes - check the dimmer
no - cluster issue (connection/bulb)
Old Jul 22, 2018 | 07:56 AM
dlx111's Avatar
No just cluster
dlx111
Lighting
Nov 1, 2018 07:29 AM
weekendboost
Apr 8, 2013 08:38 PM
eg6REDmilano20
Jan 11, 2010 01:35 PM
