So my 95 lude is sitten on 18s front and oem 15 rear..bye bye to that today..my question is 18's all around stock suspension . will 18s fit without issues? GETT N KILL DEAL 4 18S ON NEW HANKOOKS FOR 275.00 THEY ARE ALREADY ON A HONDA DNT KNOW MODEL ...JUZ WANNA GET PERSPECTIVE FROM OTHERS WHO MAY HAVE THIS...APPRECIATE ..AND 1 OTHER QUESTION IM A ENGINE BUILDER AND PAINTER..DNT KNOWALOT ON OTHER STUFF .WHEN I BRAKE MY CAR GOES RIGHT PRETTY INSTANT GTTA COUNTER STEER IT.AND WHEN DRIVEN AT 40 MPH HEAR A WOBBLE NOISE FRONT DRIVE SIDE .. ANY INPUT WHAT TO LOOK FOR?! WOULD B AWWWSUMM..THX GUYS.
95 TUCSON AZ ...
18" Wheels on a Prelude are definitely gonna look great and if your getting a good deal then I can see why you'd be excited. In my opinion, an 18" wheel is about the biggest you want to go on a Prelude, unless you have a showcar, with that said there are a few things to consider when putting 18's on there. If you can get us the tire size we can tell you more and if you can get the wheel offset then we can tell you even more. The main concerns are the width of the tire (as it can cause interference with the steering knuckle or strut), the overall diameter of the tire (as it can cause interference with the shock tower, fender or steering knuckle and strut), the "profile" of the tire or the "sidewall height" which is a aspect ratio between tire section width and tire sidewall height (this can effect diameter and in turn cause interference if it is too great) and the other thing to consider is wheel offset (as it determines where the wheel sits depth wise, in the wheel well). Here are some diagrams to help you learn about wheel and tire sizing:
