91 civic ef std B20 swap, can I use stock spindle?
Old Jul 16, 2018 | 06:21 PM
Yuta's Avatar
Default 91 civic ef std B20 swap, can I use stock spindle?
Can I use stock spindles for the B20 swap? My car is the DPFI 4 spd EF hatch. The only cv axles to use are the ones from 90 - 93 integra's, correct?
Old Jul 17, 2018 | 03:24 AM
EFvtec Yo!'s Avatar
Default Re: 91 civic ef std B20 swap, can I use stock spindle?
You will need DX or SI spindles as the 4spd ones will not work with the b series tranny. 90-93 integra axles will work as long as you use the intermediate shaft from the 90-93 integra. The STD is DPFI so you will need to do the DPFI-MPFI conversion as well. Its pretty easy and there are a ton of good write ups on here.
Old Jul 17, 2018 | 06:27 PM
Yuta's Avatar
Thanks!
What's the difference btw SI spindles and std spindles?
Old Jul 18, 2018 | 03:25 AM
EFvtec Yo!'s Avatar
The HF/STD spindles have a smaller spline count than the DX/SI spindles. B series axles utilize the larger spline count outboard joint and that is where the DX/SI knuckles come into play.
Hondaboy670
Sep 21, 2017 08:35 AM
rguadalupe90
Apr 30, 2014 01:54 PM
Sukka650
Feb 9, 2009 09:50 AM
grg9988
Nov 8, 2007 02:29 PM
96cxhatch17
Aug 20, 2007 10:25 AM
