Better with 2nd clutch pressure switch unplugged
Old Jul 16, 2018 | 08:58 AM
10w30's Avatar
Default Better with 2nd clutch pressure switch unplugged
2002 accord 4 cylinder automatic. 190k miles
So the car was shifting rough 1 to 2.
There are no blinking d4 lights.
so I unplugged the 2nd clutch pressure switch to see what the difference would be. Still no blinking d4. The car shifts actually better. Still has a delay and little thump when going from P to D2.
with it unplugged is the car using other info to shift gears?I guess it is better to unplug If the switch was sending crazy info to ecu? Have only driven 20 miles or so to test.
Old Jul 23, 2018 | 10:20 AM
10w30's Avatar
Default Re: Better with 2nd clutch pressure switch unplugged
Replaced the 2nd clutch pressure switch with one from ebay for 10 bucks and car shifts great.
99 dollar Dealer diagnosis with their expensive scan tool was to replace transmission. Same diagnosis from a transmission shop too !
Food for thought !
Old Jul 23, 2018 | 02:45 PM
holmesnmanny's Avatar
thanks for the update
with one going bad it's possible the other is on its way out as well, might be best to swap it out for preventive maintenance
Old Jul 28, 2018 | 03:23 PM
10w30's Avatar
Should one update the computer as the new pressure switches have new on off range ?
Old Jul 29, 2018 | 01:58 AM
nah, no need to
Old Aug 1, 2018 | 07:04 AM
10w30's Avatar
Would there be any long term effects of using 27 psi v 33 psi switches?
ZamboniDude
Acura TSX
Jan 20, 2019 03:40 PM
Bigskyguy
Nov 20, 2017 03:54 PM
jw2009
Oct 6, 2014 05:47 AM
N1civicSi
Oct 13, 2013 04:45 PM
tdog1
Transmission & Drivetrain
Nov 23, 2008 07:38 PM
