00 EX sputtering at start up / extended crank and losing coolant. Head Gasket?
hey all, I have a 2000 ex coupe stock. Purchased this car a couple months back. It appears the cylinder head has been replaced. I believe the previous owner didn't repair issues properly on this car as the dipstick was held in with a zip tie and drywall screw. And the intake manifold on there is for a manual, the car is an auto. The iacv is routed all weirdly. Not sure if this is the cause of the coolant loss. It's weirdly setup, the car has 2 iacvs on it and somehow connected by hoses, no idea what the hell they were thinking.
When ever i start the car after a drive long enough for the temp to get to operating and shut it off, it's hard to start. I have to hold the key in the start position sometimes for like 5-10 secs to get it started. Then it runs rough and evens out after a min. I'll get misfire CEL's occasionally and the light will blink indicating a misfire. Did have a p1399 but cured that with a valve adjustment.
oh and another thing that was weird is I saw mist coming out of the air vents when I had the AC on, like it was refrigerant or something. This car is the weirdest thing I've delt with.
There are a ton of things that seem to be wrong with the car, and me throwing one possible answer out is a shot in the dark without looking at the car really. You seem to have a good idea of some things that need to be fixed with the car.
Generally, I always replace the basic things with these cars when I get them. And one of those things are the fuel filter. Generally a gunked up fuel filter will give you a long crank, but obviously there are a bunch of things going wrong.
I think its a good time to replace that, as well as a general tune up on the vehicle. There is also a chance that the fuel pump could be on its way out.
Check your fuel, check your spark and you'll have an idea of what's going on.
stevenrankin20
Aug 23, 2016 05:47 PM
