Rough Start 2000 LX
Hello 👋, I am in need of some assistance.
Recently, my car has been giving me trouble starting. I have replaced the Starter and the Battery.
It sometimes doesn't start at all and you hear a single click when you try and start the car. When it does start you hear a grinding sound like if you turn the 🔑 for too long.
I have been struggling trying to find the cause of the rough starts and clicks it sometimes makes. I am able to run a wire to the solenoid and get it to start when it has the single click issue.
Thanks for ask the advice I advance.
I apologize I forgot to mention that I took those steps already I even sanded down the ground connection slightly with 2000grit sandpaper to make sure its making proper contact to the metal.
Bump. I could really use some advice. This issue is pretty terrible and I have to tap a cable directly from the solenoid to the battery to get it to jump sometimes when it quits cranking
them8te
Mar 20, 2003 10:09 AM
