99 accord no brake lights
Old Jul 14, 2018 | 07:26 AM
Richard H's Avatar
Default 99 accord no brake lights
My daughter bought a 99 accord about 2 months ago. The previous owner said she had
brake light issues. It would blow the fuse about once a month. Since then she's now having
to replace the fuse everyday or more.
I have checked the Brake fault sensor pins, the wiring plug behind the seat and replaced
the pedal sensor. I am out of ideas. Is there something else I can check that doesn't require
disassembling the entire car?
Currently all the lights are working (brake and turn) but the brake fault idiot light is on and
the turn signal light flashes fast.
Old Jul 14, 2018 | 08:54 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 99 accord no brake lights
Which specific fuse is getting blown? Fuse location and fuse no.?
Old Jul 14, 2018 | 10:32 AM
Richard H's Avatar
the neon yellow in the center. The stop light fuse
Old Jul 14, 2018 | 10:46 AM
Richard H's Avatar
stop light fuse in the engine bay. and I just verified that the ground is solid with no corrosion.
Old Jul 14, 2018 | 11:50 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
On the left side wiring harness, closely examine the wiring. There may be a short on the power wires for the brake lights and the turn signals. Although they are separate circuits, the wire may have gotten pinched and are touching. The Grn power wire is for the brake light. The Grn/Blu (green with blue stripe) wire is power for the left turn signal.
On the right side, the Grn/Yel wire is power for the turn signal. Brake light power wire is Grn like left side. Look at the wiring there too.
Old Jul 14, 2018 | 12:01 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
If the car has a tow hitch, where the trailer lighting wires may be causing a short where they were spliced in.
w8n2crz
Apr 19, 2017 06:46 AM
Mario Locatelli
Sep 16, 2013 08:26 AM
josh_db1
Aug 28, 2010 06:25 PM
dbailey
Jul 25, 2010 10:24 AM
NoSwapNoCare
Sep 28, 2006 12:47 PM
