Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
Troubleshooting: 2013 Accord: Oil Pressure light comes on when I break
Old Jul 13, 2018 | 09:07 AM
nmesolella's Avatar
Default Troubleshooting: 2013 Accord: Oil Pressure light comes on when I break
2013 Honda Accord. 65,000 miles
The oil pressure light comes on for a second or two when I break. It doesnt happen all the time, not even every day. But its happened enough so I am noticing it. Oil isnt due to be changed for another 1,000 miles and its at 40%.
Old Jul 13, 2018 | 09:10 AM
TheShodan's Avatar
Moderator
Default re: Troubleshooting: 2013 Accord: Oil Pressure light comes on when I break
That means you're low on oil. Just because it hasn't been changed doesn't mean it might not burn off a bit, especially in hot climates. Check your oil levels.
Old Jul 14, 2018 | 06:38 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Troubleshooting: 2013 Accord: Oil Pressure light comes on when I break
The Maintenance Minder calculates remaining oil life from the last time the minder was reset; but, does not monitor the oil levels or tell you if it is low. You need to regularly check your fluid levels and top off as needed.
Your oil pressure light coming on indicates it is dangerously low or some other related issue. You never want to get to the point the oil pressure light comes on. Check the oil dipstick regularly.
Jacob O'Neal
Dec 26, 2018 06:29 PM
MyUsernameName
Jun 15, 2017 02:06 PM
kevinhughes13
Apr 28, 2013 02:25 AM
beatsrmylife
Jan 31, 2013 05:21 PM
siis2fast
Nov 4, 2005 04:54 PM
