Transmission & Drivetrain Gearboxes, Differentials, Clutches
Help pics inside
Old Jul 13, 2018 | 03:14 AM
AllDay-DB8's Avatar
Default Help pics inside
Ok guys I replace all my synchronizer in my gsr transmission the transmission is been siting for 4 years. it go in to every gear when I change by hand moving the gear selector. Now when I install the shifter changer holder and used a screw driver to change gear in the rod outside the transmission. It only go in to 3 gear and 4 gear. With the case open I don’t know if have to close the case so it go in to every gear. I believe the transmission was stock between those 2 gears before I open it. Why I say that is because the lingake fell to the ground will I was driving and I could get in any other gear that why I stop the car 4 years ago. Any help would be nice thank you guys
Old Jul 13, 2018 | 09:22 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Help pics inside
Yes, the case has to be assembled to be able to cycle the selector rod into all 6 gears.
Old Jul 14, 2018 | 06:18 AM
AllDay-DB8's Avatar
Thank you brother I was about to go get a shifter changer holder a the junk yard
q16racer
Apr 19, 2011 01:48 PM
JDM-LuxurySport
Nov 19, 2010 09:21 AM
ninja 6
Honda Motorcycles
54
Mar 3, 2007 01:36 PM
gray_civic_coupe
Sep 16, 2005 01:15 PM
fullcollapse0085
May 2, 2003 10:58 PM
