Honda CR-V & Element 2WD & 4WD Element & CR-V
AC works Sometimes and Sometimes it doesn't work. why?
Old Jul 12, 2018 | 05:20 AM
SunilKPatel's Avatar
Default AC works Sometimes and Sometimes it doesn't work. why?
Honda CR-V 2009. My mechanic change the relay part. And, still it is there is same problem.
Can I change the compressor? replacing compressor is expensive. it
s about $950.00
Old Jul 14, 2018 | 06:20 PM
brandonloden's Avatar
Default Re: AC works Sometimes and Sometimes it doesn't work. why?
these years are horrible for the clutch and coil going bad. next time it goes out see if the clutch is engaged if not hit it hit a pry bar(carefully) and see if it comes one or check for power and signal at power wire when you switch on/off the ac button if it has power needs a clutch and coil
AZCR-V
Apr 23, 2018 07:58 AM
JNX
Honda Civic (2006 - 2015)
Jul 29, 2013 02:10 AM
frank316
17
Jun 20, 2011 03:44 PM
ocelotz17
May 23, 2008 06:42 PM
imjustagirl
Aug 19, 2007 08:54 PM
