Transmission & Drivetrain Gearboxes, Differentials, Clutches
Action Clutch 2MS Shudder/Bucking When Slipping
Old Jul 10, 2018 | 08:48 AM
2x0's Avatar
2x0
10 Year Member
Default Action Clutch 2MS Shudder/Bucking When Slipping
Purchased and installed a new Action Clutch 2MS (stage 5 sprung 6-puck disc with the HD pressure plate) and their chromoly flywheel late last year. I now have well over 500 miles on it of normal street driving, probably closer to 1000 miles. Which I thought would get past the break in period.
I still get a good amount of shuddering and jerking if I try to slip the clutch at all when taking off from a stand still. I can work around it if I rev it up high or take off quickly, but driving in slow moving traffic is a real pain. Reversing is even worse because of the higher gear ratio.
This is on a cable LS tranny, new Hasport engine mounts and solid front torque mount. Otherwise it drives just fine.
Is this normal?
Old Jul 12, 2018 | 11:03 AM
Aquafina's Avatar
Default Re: Action Clutch 2MS Shudder/Bucking When Slipping
That is normal. It's a trade off for a clutch setup that will hold moderate power.
mkinpwrat12g's
Jun 10, 2013 04:12 AM
blkbb6
Dec 8, 2011 04:39 AM
accord99power
Aug 4, 2008 06:54 AM
White S2k
17
Apr 30, 2003 11:17 AM
type autox
Dec 11, 2001 07:07 PM
