If you have an OBD2 ECU in an OBD1 car, such as for swapping a B20 into a 95 Civic and using a CRV ECU, these little modules will keep your check engine light satisfied for the evap system. I’m running one on my J-swapped Civic and had it on my B20 swap, too. No evap codes!
It simulates the EVAP bypass solenoid valve, the EVAP control canister vent shut valve, the EVAP purge control solenoid valve, and the fuel tank pressure sensor.
