Honda CR-V & Element 2WD & 4WD Element & CR-V
98 CR-V 4wd Rear Bearing Bad
Old Jul 9, 2018 | 10:02 AM
Jakef351's Avatar
Icon3 98 CR-V 4wd Rear Bearing Bad
Looking for some insight into repairing my CR-V. The right rear bearing is bad but im not sure if I should try just a bearing replacement or just do a whole hub assembly replacement. If I went the hub replacement route this would eliminate having to press the bearing in and out correct? Im also airing on the side of caution by replacing the whole hub in case the on in there is damaged from the bearing being bad right? Any insight or info would be appreciated.
I dont have tons of specialty tools but can rent some from auto zone if needed. Just wondering which way would be the easier route for a DIYer.
Old Jul 9, 2018 | 03:39 PM
holmesnmanny's Avatar
Default Re: 98 CR-V 4wd Rear Bearing Bad
it looks like it's just a bolt on assembly so it should be fairly easy
Old Jul 14, 2018 | 06:49 PM
brandonloden's Avatar
if i remember right the 2wd have the bolt in the 4wds have a press in if you have acess to a press its fairley easy just if you have abs make sure the magnetic side on the bearing goes down. should be the brown side
jerzey908
Apr 13, 2015 03:20 PM
papa-g
12
Mar 16, 2010 12:16 PM
PaChiLa Leader
Feb 18, 2009 05:21 PM
jasonb
Jun 22, 2002 07:17 AM
