1990 acura integra stalls
Old Jul 9, 2018 | 06:45 AM
acuracollector's Avatar
Default 1990 acura integra stalls
1990 acura integra rough idle and stall when stopped at intersection usually after about five minutes of driving. Has had a history of stalling when stopped on a slight slope but now it's stalls regularly at a stop sign or light.
Old Jul 9, 2018 | 11:21 AM
jdmark1's Avatar
Default Re: 1990 acura integra stalls
Check your ignition, cap, rotor and see how the plugs look. Spray the intake side with some water or carb cleaner (COLD ENGINE) to look for vacuum leaks. Also pull off your IACV and clean it out. It could be gunked up
Old Jul 11, 2018 | 06:49 AM
91akira's Avatar
Check your Ignition switch. The contacts can be dirty. You don't need to replace the whole switch. Just sand out the contacts.
Old Jul 14, 2018 | 05:35 PM
tamboo's Avatar
10 Year Member
DIY Ignition switch cleaning - Team Integra Forums - Team Integra
Jason Milfort
Jul 16, 2018 08:22 PM
=DA9=
Oct 4, 2005 03:25 AM
koco
Aug 10, 2004 04:25 PM
djjsc
Jul 20, 2004 05:59 PM
