Transmission & Drivetrain Gearboxes, Differentials, Clutches
Clutch super hard, cant push to ground
Old Jul 8, 2018 | 02:27 PM
Vryantec's Avatar
Default Clutch super hard, cant push to ground
I am having some issues with my build. I recently installed a new clutch and a clutch line. I bled the line, the clutch pedal would not come up the first couple pumps (so i lifted by hand) then it started to stiffen up. but for some reason my clutch is hard as a wall. Like I can not push the clutch all the way to the ground for some reason at all.. I checked to make sure the clutch wasn't seized up. Im not sure what the issue could be here. There isn't any leaks. If any of you guys had this issue or knows how to resolve it, please and thank you.
Old Jul 9, 2018 | 07:03 PM
Vryantec's Avatar
Default Re: Clutch super hard, cant push to ground
Solved. Clutch slave cylinder was seized, broke it loose and greased it.
altoid04
15
Nov 18, 2009 04:10 PM
Dre_559
May 28, 2009 08:23 PM
otakueric
Oct 6, 2004 09:44 PM
SiYouLater
May 23, 2004 11:35 AM
