Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Troubleshooting: 03' Civic car won't start due to fouled plugs & no ECM access
Old Jul 8, 2018 | 01:03 PM
johnsonoffeideh's Avatar
Default Troubleshooting: 03' Civic car won't start due to fouled plugs & no ECM access
honda civic 2003 model won't start but the engine cranks up, plugs get soaked with fuel, can't access ecu with diagnostic tool
Old Jul 8, 2018 | 06:37 PM
toyomatt84's Avatar
Sanji
Default Re: Troubleshooting: 03' Civic car won't start due to fouled plugs & no ECM access
You may have a dead ECU, if you cannot access it through a scanner.
Old Jul 8, 2018 | 06:53 PM
i thought as much, guess i needed a second opinion. been driving the car about, just noticed suddenly my fuel consumption became alarming and some times i loose compression while in motion. i also noticed my plugs were soaking with fuel. . . . thanks all the same
Old Jul 9, 2018 | 06:03 AM
thisguyaves's Avatar
frozen injector maybe, but if you can't scan then you can't scan. That's wiring of the ECU. do you still get 12V? Like does the code reader turn on initially? By friend's integra decided to stop supply 12v to the obd2 port, he hot wired it to the cigarette lighter and it worked fine
wilham320
Engine Management and Tuning
Aug 8, 2012 05:42 AM
Lucky-13
Mar 23, 2007 09:33 PM
handlebarsfsr
May 8, 2006 06:43 PM
