Adding bias adjustment and deleting abs
On my integra type r racecar I felt that the rear brakes weren't doing enough. I tried pulling slightly on the ebrake while slowing from high speed and I found it settled the rear end down alot. This is a powerful turbo car with a bbk on the front so it would unload the backend while high speed braking and make it want to come around on corner entry. At this point the setup was all stock except wilwood 6 piston and 12.9" rotors on the front with ht10 pads and stock rear with hp plus pads. So then to add rear bias adjustment and replace my corroded stock lines I bought the chase bay booster delete and brake line kit with bias adjustment. It's pretty bad, the pedal feel is brutal and the front brakes stick a little bit. Now I'm looking at buying a non abs 1" master cylinder, reinstalling the booster and teeing off the front brakes from the front port and running the rear port to the bias adjuster and then teed to the rear brakes. I know people love the itr abs but the back brakes didn't seem to be doing anything. Any advice on what to do with the brakes on this car?
stop spending money on brakes and fix/modify the suspension setup so that the front can handle the weight transfer sand not unload the rear of the car so much, your chasing the wrong system on the car
There are no rubber bushings left on the car, all spherical or some pcl bronze bushing in a few spots. The coilovers are AMR 900lb fr and 1000lb rear. The car doesn't dive it just depends on the front brakes too much. It's been corner weighted and aligned last week. It's likely just something I have to live with like the massive amount of torque steer.
0.04 toe in on the front, all the solid bushings as mentioned and I bought different wheels to improve scrub radius. Now 17x9 ×35 with 255/40/17 r88r in the front and 235 in the back. Its definitely better but I'm still using the itr diff. Upgrade this off season.
I've had great success with using two different pads front and back. HP+ in back. They have great bite until temps get up there, but since they are in the rear, temps never seem to get hotter than their optimal range.
the problem is only solvable to an extent, we have tiny rear brakes and a tiny bit of weight in the rear. i can tell you that the majority of guys i race with put a stock type rear pad in and forgot about it, i know of racers who have literally clamped off rear brake lines to try and stop lifting/rear lockup and even that wont do it. adjustable bias will help, but the majority of the answer lies in fine tuning the front spring rate and rear rebound and a good spherical compliance bushing like the ones from kingpin.
the car absolutely does dive, thats vehicle dynamics 101. i dont know anything about amr dampers, but i can tell you your front spring rate is a little light depending on tire. have you done shock adjustment testing? adding rear rebound would be a good idea.
the speed and horsepower dont change the amount of weight transfer/force only the amount of time/distance it spends transferred. what tires are you using?
bias adjustment can only be so helpful before it becomes problematic. you have nice big wilwoods in front yet you are moving braking force to the rear that cant handle the heat as well, will screw with handling characteristics and extend stopping distance. i have adjustable bias on my car, i was able to go 1 full turn towards the back before things got funky. i wound up with like a half turn just to ease some lockup.
what are your corner weights?
Toyo R888R 255/40/17 fr 235/40/17 rear
the car weighs 2480lbs and was balanced to 50.2% but I can't find my pic of the exact weights
0.03 toe out and 1.7° camber
I had a little toe out in the rear as well (more than you) and she was all sorts of wiggly under braking. I brought it to "in" an 1/8" and it made a dramatic difference in stability under braking.
aw614
Oct 9, 2015 02:28 PM
Tharshan
Suspension & Brakes
18
Nov 21, 2013 01:56 PM
