Transmission & Drivetrain Gearboxes, Differentials, Clutches
2000 honda CRV torque converter and flex plate
Old Jul 6, 2018 | 02:37 PM
honda time's Avatar
Default 2000 honda CRV torque converter and flex plate
First, how far in should the torque converter sit inside the transmission housing? Should it be almost flush with the housing or sit in 1/8 inch or so?
Second, what should the gap be between the torque converter and flex plate before they get bolted together? Should they be just far enough apart for each to spin independently by hand?
Old Jul 7, 2018 | 02:42 PM
holmesnmanny's Avatar
Default Re: 2000 honda CRV torque converter and flex plate
you need to spin the torque converter until it clicks either twice or three times as it sets
you need to research to find it for the vehicle, normally it's 2 times but it could be 3
if you just sit it up there it's going to get damaged it needs to be properly seated by clicking
you can pick up a shop manual
https://www.rockauto.com/en/catalog/...r+manual,10335
Hardtack
Honda Insight & CR-Z Hybrid
Apr 30, 2018 05:42 AM
Zudick
Honda CR-V & Element
Apr 20, 2017 06:40 AM
decemberr
Apr 14, 2017 08:51 PM
smxcan
Jan 12, 2009 07:17 PM
26street510
Feb 12, 2007 03:43 PM
