Anyone familiar with or have a diagram for the A/C wiring on an 02 accord?
Old Jul 6, 2018 | 10:34 AM
rorik's Avatar
Default if you have an H22 swapped 02 accord with a p28, does your a/c work?
Hey, I was just wondering if anyone has a wiring diagram for the A/C on an 02 accord, or more or less knows how it's wired up. My fans are not coming on with the compressor. The A/C works, but only if the car is moving, or if it's windy enough when sitting at a stoplight. The fans both come on with the coolant temp switch to cool the motor, so the fans and relays are both good. The fans just aren't getting the signal to come on when the A/C compressor comes on. Are there separate wires coming from the ecu that control this, or does the car have a separate a/c control module, or what? 02 accord coupe, h22a4, p28 ecu. Is my p28 programmed incorrectly somehow?
Thanks for any help, this is really annoying.
Old Jul 9, 2018 | 01:10 AM
bw77's Avatar
Default Re: Anyone familiar with or have a diagram for the A/C wiring on an 02 accord?
Go here:
BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
Click on wiring diagrams.
Old Jul 17, 2018 | 01:57 PM
rorik's Avatar
Thanks for the link. Guess I have to figure out if A12 on the P28 is grounding when the a/c is on, and see it that's connected to the right wire on the obd2b to obd1 jumper harness. Idfk
JDMCRX
Feb 9, 2009 06:16 AM
Safir
Jul 13, 2004 06:53 PM
chictunner97ex
May 13, 2004 01:57 PM
titos99
Audio / Security / Video
Feb 19, 2004 09:10 PM
