Weird Noise 🤔 Need help figuring it out
Old Jul 5, 2018 | 09:34 PM
d155spd's Avatar
Default Weird Noise 🤔 Need help figuring it out
Well, my ‘90 EF Hatch has developed a rather odd noise. Imagine it as an almost Rod-Knock sound, but not rod knock and quieter. At idle in neutral it does it at what sounds like the same speed as the engine is idling, and also does it when the car is slowly rolling in neutral, it might do it when it’s rolling and going quickly in neutral but I just can’t hear it. My best guess is a throw out bearing, but I wanted more opinions. Just happened randomly one day when I turned on the car. Swapping motor to B18b1 very soon, so I’m not super worried, but is my daily until I find a cheap beater to get me through the swap. So any help is appreciated. D15b1 with the 5spd. DX model.
Old Jul 5, 2018 | 11:14 PM
holmesnmanny's Avatar
Default Re: Weird Noise 🤔 Need help figuring it out
does the noise go away when you press the clutch pedal down ?
Old Jul 6, 2018 | 09:43 AM
Kramer5702's Avatar
Sounds like the throwout bearing to me, as the last poster asked, does it go away with the clutch pressed in? If so it's more than likely that. I've driven vehicles with chattering throwout bearings for a while before they actually went out completely. Not recommended lol
Old Jul 6, 2018 | 10:36 AM
d155spd's Avatar
Yep, goes away when clutch is pressed in. :/ well I hope it doesn’t lock up on me and strand me somewhere, I guess.
Old Jul 6, 2018 | 11:25 AM
Kramer5702's Avatar
If it locks up hopefully you're near home lol, I drove my old s10 like that for 2 years hahaha, I was lucky
Old Jul 6, 2018 | 05:45 PM
DaX's Avatar
DaX
Loved
Community Favorite
If the noise goes away when the pedal is depressed, it's likely the input shaft bearing inside the transmission and not the throwout bearing.
Old Jul 9, 2018 | 08:29 PM
d155spd's Avatar
DaX, if that were the case, how imminent is it that my car will **** out on me at any moment..?
Old Jul 10, 2018 | 03:02 AM
DaX's Avatar
DaX
Loved
Community Favorite
I've had one grenade on me before and it took out the input shaft seal (and part of the case :/), so it dumped most of the oil out of the transmission in less than a day. But you'd know it if this happened - it was really loud. I've had other transmissions that roared a little and I drove them for somewhere between 8-12 months before I took the transmission out and replaced the bearings. I personally wouldn't wait a terribly long time to get it fixed.
Old Jul 10, 2018 | 08:35 AM
d155spd's Avatar
As I said, I’m just gonna roll with it until it blows. Because I’m putting a new motor/trans in anyways. But I was just seeing how long it’d last and what the noise might be, thanks for the help though guys. Always appreciated.
Old Jul 10, 2018 | 09:55 AM
ChiantiHatch's Avatar
Mine is doing this, it goes with rpm (more at 3rd or 4th gear low rpm) but doesn’t do it at idle just did clutch and flywheel bearing after it started. It only helped it. I’m pretty sure it’s the input shaft bearing inside the trans,
I’m gonna go B soon as well so not worried too much about it.
Old Jul 11, 2018 | 02:54 PM
if it's making a knocking sound it's probably close to seizing up
normally they just make a roaring sound for a long time
Old Jul 14, 2018 | 10:04 AM
d155spd's Avatar
Well she made it to the beach and back and it’s still going so 🤷🏼*♂️
kyle0209
Honda Civic (2001 - 2005)
Oct 20, 2016 01:59 AM
2xb18c6
Jun 23, 2016 05:24 AM
mayfly
12
Aug 4, 2009 04:09 PM
quikrpm'z
Mar 11, 2004 04:42 AM
DeDonDeRosa
Nov 23, 2002 09:03 AM
