What aftermarket B series wiring harness is a good company?
Swapping to a B20b ,What aftermarket B series wiring harness should I use ? What are very good spark plugs aswell? And what would be a good ecu to use other than hondata , Recommendations on a very good setup for all motor ?
A factory harness works the best. Critical wiring is shielded in a OE harness, whereas, aftermarket harnesses do not utilize this type of construction and thus are more susceptible to electrical and RF interference. NGK and Denso spark plugs are the most common quality spark plugs for a Honda application. What is your issue with a Hondata ??? When it comes to value, the s300 is a feature-packed product that is very affordable. Finally, what is your HP goal for an all motor B20B ???
busychild
24
Jul 7, 2013 05:03 AM
