Honda Civic Si ignition switch
Old Jul 3, 2018 | 06:28 PM
Tido831's Avatar
Default Honda Civic Si ignition switch
My friends 99 Civic Si won't start; battery, fuses and fuel are good. The car runs of we jump the starter and give the ignition switch direct power from the battery. The clutch safety switch is there and when we insert the key to the run position the dashldash l don't turn on but the headlights and hazard work fine.
Helpful tips welcomed and thanks in advance.
Old Jul 3, 2018 | 08:38 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Honda Civic Si ignition switch
So no warning lights are on when the key is in the "run" position ??? If you continue to rotate the key to "start" does the engine turn over ??? If not, do you hear any sounds at all ???
Old Jul 3, 2018 | 08:43 PM
Tido831's Avatar
No lights turn on when the key is in the run position or to do a bulb check
Old Jul 6, 2018 | 02:21 AM
NVturbo's Avatar
O.G. triple O.G.
did you guys happen to check fuses under the dash??
Old Jul 6, 2018 | 03:40 AM
mk378's Avatar
The two white wires on the ignition switch should be always live from the battery. They are fed from the underhood fuse box. Check for blown main fuses in that box. The headlights / tail lights and hazards are also supplied by the underhood box, but on independent circuits with their own fuses.
Old Jul 6, 2018 | 05:45 AM
Tido831's Avatar
Thanks, I'll double check the fuses, and look at the wiring diagram again
Tido831
Jul 10, 2018 09:39 AM
sandyshore43
Feb 26, 2014 07:44 AM
KleanEj1
13
Dec 30, 2009 02:43 PM
Honda Virgin
Jun 2, 2004 12:34 PM
JToolz
Feb 15, 2004 06:56 PM
