Brake Lights stuck on
Old Jul 1, 2018 | 09:14 PM
thrust's Avatar
Default Brake Lights stuck on
I replaced the broken plastic plunger in the pedal that pushes the sensor pin that turns the brake lights off and it worked but after 10 minutes or so the brake lights still remain on. I push the pedal and release and the lights turn off but after 5-10 minutes the brake lights go back on. Im guessing the actual sensor is faulty now.
Has anybody else have similar story?
I look under the dash and the brake pedal and i can clearly see the pin getting pushed in by the plunger and the light turns off but after 10 minutes the light comes back on.
Any help is appreciated.
Old Jul 2, 2018 | 02:43 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Brake Lights stuck on
bad brake pedal sensor
Old Jul 5, 2018 | 10:19 AM
91akira's Avatar
I never heard of this sensor going bad. If you do replace this thing, can you give us feedback like where did you purchase them and if it worked. Thanks
Old Jul 6, 2018 | 05:19 AM
jnk's Avatar
jnk
I would say bad unit overall man, try get a spare one from the wreckers, it shouldn't be too hard to find...
Nderuso
Dec 30, 2019 08:43 AM
chighizola9
Jul 20, 2013 01:46 PM
SpazMan
Jun 22, 2009 08:44 PM
devious
Mar 9, 2009 12:17 PM
slowassR
Sep 3, 2003 08:43 AM
