Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Recharging AC system
Old Jul 1, 2018 | 06:42 PM
Zebra's Avatar
Default Recharging AC system
I put on a new AC compressor, so I had to discharge the entire system. I know the proper way to recharge is to pull a vacuum and use gauges to assess pressure while adding, but can it be done on the cheap by just adding refrigerant? The compressor doesn't come on, and it appears refrigerant won't go in without the compressor running. Some jump the terminals to activate the AC clutch, but I don't want to inadvertently fry the system. The system should be relatively free of contaminants, as the clutch bearing was the issue with the previous compressor. Is there a way to add refrigerant in a completely depleted system?
Old Jul 2, 2018 | 02:52 AM
holmesnmanny's Avatar
Default Re: Recharging AC system
you don't charge by pressure, you charge by weight, and if the compressor exploded you must replace the condenser
Old Jul 3, 2018 | 05:44 AM
rick_rabies's Avatar
I'm not Rick!
recharge.....or charge? big diffy
Old Jul 3, 2018 | 03:10 PM
Zebra's Avatar
[QUOTE=holmesnmanny;51673635]you don't charge by pressure, you charge by weight, and if the compressor exploded you must replace the condenser
https://www.youtube.com/watch?v=Pdq8JAlct6s[/QUOTE] The clutch bearing was going out - the compressor itself was still good. I wrecked the old compressor when I tried to remove the clutch pulley. Can you introduce refrigerant to the system without the compressor engaged? I don't have access to a vacuum pump or gauges.
Thanks for the video reference.
Old Jul 4, 2018 | 07:16 AM
Zebra's Avatar
Charge - the system was disconnected and totally discharged.
Old Jul 4, 2018 | 02:01 PM
[QUOTE=Zebra;51674978]
you turn the ac on and the clutch will turn on when you get a minimum amount of refrigerant in the system
but, again, you charge by weight so use a scale just like he does in the video
Old Jul 4, 2018 | 02:35 PM
sumdewd's Avatar
Recharge? Sure. Charge? No. You need to pull a vacuum on the system no matter what. It will not turn on unless you have a 'static' charge of refrigerant to trip the low pressure cutoff, which is usually 3-5 ounces in these systems (enough to condense into a liquid). That static charge will not draw in unless the system is under a vacuum. The oil is also carried by the refrigerant. If you choose to jump the compressor without refrigerant you may cause several hundred dollars in damage to your car or A/C unit.
If you somehow get a refrigerant charge in without a vacuum, you will now have mixed it with a bunch of air and moisture, which will then add its total atmospheric pressure on top of the refrigerant's static pressure (rendering your system basically useless) and it will not run properly. Moisture also slowly turns most PAG oils into an acid, which will slowly destroy the system from the inside. When mixed in a closed system like this, air adds its total pressure on top of the refrigerant (creating unrealistic pressures across the board), and not entirely proportionate to the amount of them in the system. Once again, it's mission-critical to pull a vacuum in a closed A/C system. It's so retarded I honestly don't have something else to compare it to. A/C units need a vacuum or they don't work... Plain and simple.
TLDR; You need a set of manifold gauges and a vacuum pump, or take it to a shop. Your pick.
Old Jul 4, 2018 | 03:03 PM
yes, definitely make sure to pull a vacuum for atleast an hour prior to charging
i was under the impression you knew to do this first as is demonstrated in the video
Old Jul 4, 2018 | 09:40 PM
Zebra's Avatar
Thanks - there obviously is no short cut, as implied in some of the YouTube videoes.
Old Jul 4, 2018 | 10:28 PM
and in your original post where you asked about going at it the "cheap" way.
Old Jul 5, 2018 | 04:32 PM
Zebra's Avatar
Less expensive, if still efficient.
skshow289
Feb 17, 2018 01:12 PM
75aces
Mar 4, 2011 03:10 PM
4doorcivic16
May 14, 2010 04:39 PM
shannon
Feb 6, 2004 10:03 AM
Trey
Jul 14, 2003 08:58 AM
