Idle drops
Old Jun 30, 2018 | 04:08 PM
Ttrip's Avatar
Default Idle drops
I have a 1999 Honda accord lx vtec v6 when i step on the brake pedal the rpm drop from normal to almost a stall, release brake and rpms start returning to normal. Can this be do to a failing brake power booster?
Old Jul 1, 2018 | 01:03 AM
holmesnmanny's Avatar
Default Re: Idle drops
we've heard from someone that says changing the check valve in the brake booster hose fixed an issue like this
i would say try grabbing another from the junkyard for the same car, i believe the check valve is built into the hose on your car
even a new one is only $20 but I would say just pull a junkyard one and see if that fixed it, cheap try at a fix
be sure the hook the hose up in the correct direction
https://www.hondapartscheap.com/oem-...er-46402s87a00
looks like any v6 98-99 accord uses the same hose so those are your vehicles to pull from
bdr_one
Feb 4, 2015 06:39 PM
Mr learns alot
Sep 28, 2014 01:55 PM
RKA
Nov 19, 2005 07:05 AM
swiftstyles
Jan 12, 2004 02:12 PM
