NEED HELP WITH MY 1998 HONDA CIVIC EX
Old Jun 28, 2018 | 06:32 PM
Jcironworker's Avatar
Default NEED HELP WITH MY 1998 HONDA CIVIC EX
Hey guys I need help here, I have a d16b in this Civic and for some reason nothing will work in side. NO DASH LIGHTS NO ELECTRIC TO THE WINDOWS. But I have power to the locks and the radio turns on. I try to start it IT CRANKS BUT DOES NOT TURN OVER NO LIGHT ON DASH NOTHING. I have a brand new battery cleaned all the grounds and checked the fuses everything good. I HAVE NO IDEA AND I NEED SOME HELP HERE.
Old Jun 28, 2018 | 07:02 PM
Gattlin's Avatar
Default Re: NEED HELP WITH MY 1998 HONDA CIVIC EX
has it been in an accident? maybe some part of the wiring harness got pinched/shorted/cut. just a thought.
Old Jun 28, 2018 | 07:48 PM
no accident checked the wire harness it looks okay. But I was just driving it 3 days ago and hasn’t started since. Idk not sure how to fix this.
Old Jun 28, 2018 | 08:29 PM
jonsey1886's Avatar
10 Year Member
Check the ground mounted on the thermostat housing, also check to see if you fuel pump is engaging (you should hear it prime when you first turn the key to accessory).
Also you checked BOTH the under driver dash fuse panel and the fuse box next to the battery right?
Old Jun 29, 2018 | 01:13 AM
The fuel pump does not engage I have no power to the dash and yes checked the fuses in both areas. There is no ground on the thermostat.
Old Jun 29, 2018 | 08:02 AM
jonsey1886's Avatar
10 Year Member
And there is your problem pal That ground is for the PCM (Engine ECU), hence the reason you aren't getting power where it needs to be. Diagrams below.
From: https://honda-tech.com/forums/honda-...tions-1998336/
"Ground Wire Locations"
Photobucket
Photobucket
Old Jun 29, 2018 | 12:49 PM
I have a ground connected there now and still nothing???
eljah0426
Mar 7, 2011 07:53 PM
jdm-chato
Jan 26, 2011 11:16 AM
Wdpfreak145
Aug 17, 2010 10:50 PM
pjr710
Audio / Security / Video
Aug 22, 2007 11:52 PM
usdm.ehtu
Mar 17, 2007 07:54 PM
