1997 Honda Accord quitting issue
I have a 97 Accord with a f22b2 enginethat runs great for about 20 minutes, then gives me a p1361 and P1381 code and shuts off. After sitting for about 5 minutes it will start up again and go, sometimes in limp home mode, sometimes not. I have replaced the crank position sensor and all the electronics in the distributor. I recently replaced the cylinder head and timing belts. I’m also getting an oxygen sensorcode that I believe to be unrelated. I need some ideas about where to go from here if anyone can help.
I did. I’ve noticed when it’s cooler out it runs longer before it quits. Today it made it to work without quitting. Some days when it’s hot it quits 3 or more times. Each requiring a 5-10 min cool down period before it will restart.
i'd be more inclined to think it was the distributor causing the issue, might be best to just pull a junkyard distributor to be check
I replaced the electronics in the distributor with a set from the junkyard and it has a new cap and rotor. The only part I didn’t replace was the housing itself and the shaft. I was also wondering about the coil. Could that be cutting out when it gets hot?
exactly what did you replace ?
dooner518
Jul 15, 2017 08:47 AM
