I've got 2 Leaks I think. 1 Oil & 1 PS Fluid cause the PS Reservoir Bubbles while running.
I've changed the Valve Cover Gaskets when not too long ago. Does it look like it's still leaking from there? If so, could I use some Sealant on the outside? Just replaced the AC Fan and now Coolant is low too. Radiator & Reservoir.
Sorry about that. 2000 accord LX 3.0l v6 auto 189k
Would burning coolant turn brown color? I've cleaned this spot off before but can't quite pinpoint if it's coming from the thermostat housing or elsewhere . The VC's are good.
