95 Honda Accord no torque converter lockup
Old Jun 26, 2018 | 01:12 PM
rode2nowhere's Avatar
Default 95 Honda Accord no torque converter lockup
95 Accord ex, 2.2, 4 speed automatic, converter lockup used to work, it gradually quit, my d4 never flashes, any ideas greatly appreciated
Old Jun 26, 2018 | 01:42 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 95 Honda Accord no torque converter lockup
Verify there are no stored codes, just because the D4 or CEL lamp are not illuminated does not mean there are no codes. Also verify the CEL lamp works. CEL and D4 lamp should come on when you first turn the ignition to 'ON'. If they do not when the Main Relay initially turns on to prime the pump then you will need to replace the CEL or D4 lamp. Before checking codes.
The pair of upper solenoids are what controls the TCC system.
Disconnect the harness to the upper solenoid pair.
With a jumper wire power the solenoids directly with battery power.
They should have an audible click ON and OFF.
If they don't the solenoid may be stuck, you may try to loosen it by using the stem of a Q-tip. Cut off the cotton ball part, insert stick into solenoid center hole and see if you can feel the pintle valve move.
If they click with battery voltage, you will need to check the screens.
Unbolt the solenoid, 10mm headed bolts.
Gently prise the solenoid up, be careful of the rubber O-ring gasket.
Gently pull it off and check the two metal screens are clear of debris and junk.
How did you determine the converter was not locking rather than it being a gear?
Old Jun 26, 2018 | 02:38 PM
I can tell the rpm is higher, also the converter should unlock when you tap the brake, I see no change in rpm, thank you for your time by the way
Old Jun 29, 2018 | 04:36 AM
Screens clean, both click with 12 volts, and resistance is good, anything else I can do?
Old Jun 29, 2018 | 01:02 PM
MAD_MIKE's Avatar
MM Gruppe B
You did verify that the fluid was full?
Did you check for any stored codes? Several AT codes will not illuminate the D4/CEL lamps.
Old Jun 29, 2018 | 04:20 PM
fluid is good and no codes
LuGaru_Pt
May 22, 2013 11:20 PM
eingman
Sep 17, 2012 05:11 PM
sneaks
Oct 6, 2010 02:58 PM
titosek4
Aug 31, 2009 09:02 AM
EgK2o09
Oct 30, 2007 12:47 PM
