Check Engine Light code P1259, VTEC system malfunction
Old Jun 25, 2018 | 08:39 AM
reedsh2's Avatar
Default Check Engine Light code P1259, VTEC system malfunction
2002 Honda Accord LX, 2.3L
Old Jun 25, 2018 | 08:47 AM
reedsh2's Avatar
Default Re: Check Engine Light code P1259, VTEC system malfunction
I also have the code for P0706- a malfunction with the Transmission Range Sensor Circuit Range/Performance. Both codes appeared around the same time and the car drives normally except it will jump into second gear and if i accelerate too hard the RPMs downshifting will go nuts on me so i've taken to babying the accelerator so as not to inspire any serious problems, I've also observed a noticeable decrease in fuel efficiency.
Old Jun 25, 2018 | 08:51 AM
somick's Avatar
Oil level?
When was your last oil change?
Old Jun 26, 2018 | 02:01 PM
MAD_MIKE's Avatar
MM Gruppe B
Range sensor is exterior on trans case. Check behind the right side wheel, look for any new damage.
Has there been any recent work done on the car? It may be a loose wire or harness issue.
wlanford
Feb 18, 2014 08:16 AM
36Chitownrunnin
Jun 17, 2008 08:44 PM
Neldawg
Jul 16, 2006 11:00 AM
nelson69
Oct 30, 2005 05:13 AM
MG6
Jul 28, 2004 11:53 AM
