97 Acura Integra Gsr Help!!
97 Acura Integra GSR
All other electronics work just fine in my car besides the turn signals and the wipers.
Few weeks back i decided to do an interior swap on my integra. After the swap everything seemed to work just fine except for the turn signals. Everything is plugged in, checked the fuse #23 and it was good. Checked the relay for the turn signals with my friends integra “No issue”. Though for some reason my turn signals aren’t getting any power to them. I read a forum post on here about checking the multifunction box and or replacing on the back of the fuse box “White box”. The headlight and high beams work and also my hazards. I read another post inside the same forum post someone said to make an inline connection to the green/white wire to a 12V connections but I don’t know what that means exactly.
When driving around last week I just ran into the issue of my wipers not being able to turn off at all. The back wiper still works but the front wipers won’t stop.
i need some insight. Please help. Pictures would be awesome or even an actual video since there are none at ALL.
I’m going to record a video of my car today after work and post it here. Hopefully that will help understand. No one in any videos show the color wires for the turn signals, how to check if they still have power and how to fix a turn signal issue.
Conclusion for what works and what doesn’t;
Works:
Fuses are 100%
Head lights work
High beams work
Hazards work
Rear windshield wiper works
Don’t work:
Turn signals don’t work
Wipers won’t shut off
Works:
Fuses are 100%
Head lights work
High beams work
Hazards work
Don’t work:
Get a multimeter and a service manual, and prepare to spend a few hours crawling around under your dash. I'd start at the flasher relay and work my way from there.
Thanks @tamboo for the manual! I plan on using my friends multimeter later on today to check the wires. Will post in the next few days updates if I get my signals working or not and how I fixed the issue.
I was was able to fix my wipers by changing out the lever with a new one. (Glad this wasn’t an electrical issue).
If anyone knows what these wire color combinations are it would be awesome to know!
Turn signal Wires:
Green/Yellow:? I think this is the right signal?
Green/Orange:? I think this is for the ground?
Green/Blue:? I think this is left signal?
These are color combinations for what’s plugged into the back of the turn signal lever that controls the signals only.
Just weird that that only my signals aren’t getting power to the lever.... cleaning up the last owners mess of wires that were just thrown behind the dash. Thanks everyone!
Turn signal Wires:
