From: Michigan, our roads aren't as bad as Toledo, OH's
98 Accord 3.0L TRANSMISSION swap w/ 2.3L 5speef?
Would swapping out my automatic transmission to a 5-speed manual be possible? I've seen my friend swap is automatic transmission with a standard in his truck... this is something I would really like to do. I understand all that entails as well. Fabricating a clutch pedal fabricating a clutch Reservoir etc
edit: I've found some more information, I found an old video of some guys swapping the 03 Acura CL 6 speed transmission into his car, here's a price list
Reason: Found new info
You would need to use the six speed from the later 03-up 3.0 or J-series cars. Differential would be on the wrong side for your car if you attempted to use a F/H trans.
