Suspension & Brakes Theory, alignment, spring rates....
Is Amr engineering still in business??
Old Jun 24, 2018 | 06:39 AM
woodlock33's Avatar
Default Is Amr engineering still in business??
I've been trying to get ahold of Amr engineering for a couple weeks now with no luck. Can anyone confirm that they are still available ? I’m ready to order my coilovers.
Also can anyone answer whether or not the amr coilovers adjust ride height through the shock body or through the spring preload ?
I was going to go with ground control coilovers but I don’t like that they lower height through spring preload perch which causes a loss in shock travel.
Turn around time on GC coils is a few days and I’ve read that Amr coils are a few weeks.
Thank you in advance for for anyone who can answer my questions
Trying to get these tires tucked asap
Old Jun 24, 2018 | 12:24 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Is Amr engineering still in business??
AMR's are full body adjustable. You can adjust ride height independent of spring position.
not sure if they're in business.
Have you called them? Or just email?
Koni/GC works best with like a 1.25 or 1.38" max drop. Not really the system you want if you want to slam the car.
Old Jun 24, 2018 | 02:22 PM
woodlock33's Avatar
thanks for the info on the height adjustment it looked to be that way but just wanted some confirmation.
I’ve called multiple times, emailed, tried their website live chat, hit them up on Facebook and Instagram!
The ground control setup I am looking at is a full Coilover
they have up to 4in of lowering but it’s all through preload and loss of stroke in the damper which I don’t like.
https://groundcontrolstore.com/colle...nt=36602716867
not to be confused with GC/Koni setup
Old Jun 24, 2018 | 04:34 PM
B serious's Avatar
^That kit looks like it includes custom shortened koni yellows that can slip down on the shock fork further also.
Nice idea by GC.
Unfortunately....
You'll still have issues with the UCA hitting the shock tower.
You need to lose bump travel to some extent so that the bump stop is active early enough to prevent that.
If you just lower the car and keep a lot of shock travel...something else is going to hit something else.
The reason the stock shocks are the length they are is so that the shock and bumpstop control wheel movement.
You can customize all of that with a full body coilover by using a measuring tape and an hour or so of setup time.
Have you tried Fortune Auto?
Old Jun 26, 2018 | 04:56 PM
woodlock33's Avatar
Nice idea by GC.
Unfortunately....
I understand all of that
thank you
I ended up ordering the ground control special purpose coilovers
I ended up opening a wholesale account with them through my shop sooo yeah
it’s nice to work in the industry
hopefully have everything installed by end of day Saturday. Gotta order all the control arms and usjustable links tonight
Old Aug 2, 2018 | 10:16 AM
hybridnorth's Avatar
Why not a set of kw v3's? Price is similar and a nice product?
GSR615
Suspension & Brakes
Jun 13, 2010 05:48 PM
SlowEJ8
Suspension & Brakes
15
Apr 29, 2009 07:00 PM
OutlawCL
Suspension & Brakes
Mar 6, 2006 09:51 PM
92integraVTECgsr
Suspension & Brakes
Nov 22, 2005 10:44 PM
allmotorEG-SI
Oct 16, 2001 05:41 PM
