Are the SI rear trailing arms compatible with the del sol S.
Old Jun 23, 2018 | 08:32 AM
Elijah Trevino's Avatar
Default Are the SI rear trailing arms compatible with the del sol S.
Hi I'm just wondering if the rear trailing arms on a del sol Si are compatible with a 95 del sol S as far as clearing and the E - brake cables
Old Jun 23, 2018 | 08:29 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Are the SI rear trailing arms compatible with the del sol S.
The trailing arms are interchangeable... but if you are using a different rear brake type, you will need the cables that match them. For example, you cannot use "S" drum brake E-brake cables on "Si" disc brake calipers... you MUST have the disc brake cables from the "Si" chassis with the trailing arms.
424racer
15
Apr 25, 2010 07:48 PM
KodSol
Apr 10, 2007 01:10 PM
Eg2707
Dec 21, 2006 12:45 PM
BlueIntegraBoy
Apr 14, 2005 08:47 PM
go2sleep
Jun 15, 2004 10:51 PM
