Honda CR-V & Element 2WD & 4WD Element & CR-V
ECM swap 2007 Element
Old Jun 21, 2018 | 09:17 AM
jwluge's Avatar
Default ECM swap 2007 Element
I have a 2007 element and was getting a engine code U0107 so I found a good ECM with the same part number match and year,model and auto trans. I made the swap and engine is not starting, turns over but not firing!!!??? the old EMC starts the engine but no throttle response! HELP! does the ECM need to be programmed for reconizing the change???
Jim in NH
jwluge@aol.com
Old Jun 21, 2018 | 03:46 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: ECM swap 2007 Element
Yes, due to the Immobilizer System, the ECM/PCM must be reprogram to accept your current key's transponder chip.
Twilightepitaph
Aug 12, 2006 08:18 AM
blkonblkhatch
Mar 8, 2006 07:15 AM
civickid32
Aug 31, 2004 01:41 PM
