Rear passenger camber
Old Jun 20, 2018 | 08:03 PM
trm4life's Avatar
Default Rear passenger camber
So I have a 92 integra hatch that was in terrible shape when I bought it. I replaced all the bushings except the compensator arms because I have to cut the bolts, as usual. I have poly bushings and newish aluminum rear control arms.
I noticed when I was replacing the trailing arm bushing on the passenger side, the body was damaged so bad I couldn't use the factory jack location. I wedged my factory jack and a couple boards and pushed the body back out, it looked quite similar to the other side.
Anyway, my passenger rear tire is riding on the outside tread so I'm considering buying a cheap adjustable control arm. If I have to cut it to make the tire ride straight, I won't feel bad. Other option, cut my factory control arm and weld it together at the proper length. Either way it's better than the insane hydro planing I'm doing over 45-50mph with the 2 rear tires fighting each other
Old Jun 21, 2018 | 04:29 AM
CandyRedRC46's Avatar
Default Re: Rear passenger camber
are you talking camber or toe?
Old Jun 21, 2018 | 08:03 AM
trm4life's Avatar
Passenger side, top of the wheel sticks out as much as the flare on the body
Driver side, wheel is straight
Old Jun 21, 2018 | 08:46 AM
trm4life's Avatar
Camber. Recently had an alignment.
tsar
Honda S2000
Apr 3, 2010 09:22 AM
beana
Jan 4, 2010 02:08 PM
TokyoStatus
Jan 9, 2008 04:27 PM
venomzz
Dec 4, 2007 11:56 AM
Todd00
Jul 3, 2002 09:48 AM
