How easy is it to steal a Gen 1 CRV with factory immobiliser?
I live in a place that has high vehicle theft rates and I'm considering to do some security upgrades on my 99 CRV if it's to easy to override the factory security. Granted I know many vehicle thefts are as a result of the vehicle being towed away so I understand that beefed up security won't prevent that, ie you don't need to tell me that fact
How easy is it to steal a Gen 1 CRV with factory immobiliser(chipped ignition key), I'm assuming you need to swap the ECU/some computer box and then either use a matching key chip for the swapped box or the swapped box will have the immobiliser disabled so they can force the ignition lock and start the car, drive off with it?
If someone knows what the Immobilizer disables, it is not very difficult to bypass it to steal the vehicle. However, most thieves won't bother.
The thieves would have to understand what is being disabled on Hondas, which is not hard to figure out from circuit diagrams, asking someone, etc.
Then they have to locate the correct wire to directly provide power to that component.
Sorry man, I don't think you understand how a factory immo with chipped key works?
You can't often bypass them by "locating the correct wire to directly provide power to that component", you typically need to open an ECU/ECM case to do something to that effect which is a workbench job that takes hours, thieves typically use modified donor ecu's to quickly steal a vehicle with immo, unplug the stock ecu, plug in the donor start vehicle and go.
Unless you know for a fact that the CRV gen 1 has a vulnerability that allows easily bypassing the factory immo, which is what I'm trying to ascertain.
You probably don't understand the immobilizer system and what is being disabled.
Do you know for a fact that on the Gen 1 it is or you just sucking your thumb and saying it is?
