Questions about engine swap... Pros and cons of Euro R or JDM 4th gen engine swap
Old Jun 17, 2018 | 06:00 PM
allmazda's Avatar
Default Questions about engine swap... Pros and cons of Euro R or JDM 4th gen engine swap
First, I am not looking to mod the engine to get max HP. Basically the swap is to accomplish 2 goals. 1. Reliability and 2. Swap transmission for a better hwy cruising rpm.
I a new to Hondas so all of the variations and aftermarket parts are confusing to learn all at once. While the initial cost of each JDM engine is within a few hundred dollars between the 2 I am having a hard time figuring what additional cost would I incur with the Euro R if I go OBD1?
Will my current ECU (93 vtec) be able to run the JDM version? The only mods that I would do are headers and a AEM cold air intake as mine has a cheap aftermarket one now. Also PO must have jumped a curb as oil pan is dented and it has a exhaust leak. So most likely will do an exhaust upgrade as well.
The tuning aspect of this adventure has me totally confused.
Old Jun 17, 2018 | 08:21 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Questions about engine swap... Pros and cons of Euro R or JDM 4th gen engine swap
What makes you pick the "H" series engine over a "B" series ??? Keeping A/C is more difficult with the "H" over a "B"... even more difficult than a "K" swap. Your P28 ECU will only properly run the engine you had originally... you would need to convert it to a tunable system. The Hondata s300 is the most economical popular system out there... that is my recommendation regardless of which engine you use.
Old Jun 18, 2018 | 03:57 AM
TimiK's Avatar
10 Year Member
F20b swap would be the most reliable
And of course you need proper ecu/tune for the engine
Accord engines nees some electric work to be done since theyre obd2b and wiring is little bit different than in preludes
havikprelude
May 18, 2010 04:28 PM
tham1ll
Jun 17, 2007 02:18 PM
blkonblkhatch
Mar 8, 2006 07:15 AM
FlyWithMe825
Sep 28, 2004 10:58 AM
Paulnsx
Jul 27, 2004 11:05 AM
