Suspension & Brakes Theory, alignment, spring rates....
Need sway bar mounting info. Please help.
Old Jun 17, 2018 | 01:13 PM
stallinrawlings's Avatar
Default Need sway bar mounting info. Please help.
i am trying to work out mounting a rear sway bar, and I need to know the distance between u-shaped mounting brackets on the rear sway bars, and the physical “width” of the sway bars of:
92-96 prelude
97-01 prelude
94-97 accord
98-02 accord
02-06 rsx
03-07 accord
i would use the civic sway bar I’ve got, but the mounting points for the u bracket placement are a couple inches too close on each side for what I’m doing.
all I need is for anyone who has one of the cars listed above to take a tape measure and measure the distance between the brackets.
for the physical width, what I mean is this:
sway bar arm -> \__.____.__/ <- sway bar arm
Sway bar brackets ^——^
from arm to arm.
trying to get measurements to see if one will fit.
thanks all
Last edited by stallinrawlings; Jun 17, 2018 at 02:11 PM. Reason: Had more to add. (Again)
NovaRex
May 23, 2016 07:17 AM
JDMCRX
Suspension & Brakes
Jun 14, 2008 03:53 PM
rybred
Feb 14, 2007 02:27 PM
