D16Y8 Dyno Results!!!
i dynoed my little d16y8 today at Dyno Spot Racing.
Car : 93 civic cx
Engine : 99 d16y8 sohc vtec
mods : itr aem cai, rs*r 4-2-1 header, stock cat and RS*R cat back exhaust
Results : 125.8whp and 110 torque.
ill post the graphs later on tonight
Thanks Lawrance for all the help!
[Modified by Downeybear1, 11:06 PM 11/12/2002]
[Modified by Downeybear1, 12:45 AM 11/13/2002]
Car : 93 civic cx
did you ever find any HA`s? I`m glad you didn`t wait, they are still stuck in the pacific.
Ryan
Ryan
When I was at school(UTI) we dyoned a stock 99ex with a intake it mad 107 to the wheels. So I think you are doing pretty well. Keep it up your power will only go up if you take care of it
any track times?
ive got stock 170k old *** cx suspension which sucks and falken azenis which arent the best drag tire
what ecu are u using?
I dynoed a chipped P28 (dohc vtec program) and i lost alot of low end and mid, but gained about 2-3 whp up top. not worth the 25% decrease in gas mileage!
From: kapalua,los angeles,las vegas, HI,CA,NV, United States
any track times?
i ran it bone stock about 2 months ago and it ran 15.5 @ 88 with a 2.3 60ft
I really should dyno mine as well. I have similar mods. AEM CAI, HP Racing 4-2-1 header, testpipe cat, and N1 catback exhaust. I really need a P28 because this P2P is a POS. I hope to see your track times.
damn! those are good numbers. i have seen some 1st gen B16s that can barley do that...
Great numbers, what kind of mileage on the motor ?
are you using a obd1 header on that? i have the same setup but with the stock manifold and i think the o2 sensor needs to be moved to the obd1 spot. sometimes it doesnt like to crank an when it does sometimes it hesitates REALLY bad. i have to stay on the gas for about 10 seconds when i crank it up to get it to run right. also when it does this alot of smoke comes out the exhaust. when i put the obd2 back on it works fine. no smoke when on obd2. no codes on either ecu. any suggestions? sorry for the long post.
nevermind i saw your sig lol.
[Modified by RR98DX, 11:10 AM 11/13/2002]
stock y8 run 15.5 either your a good driver or you have a strong motor from the factory!!
