89 dies when clutch released
Old Jun 9, 2018 | 09:14 AM
MTswisher's Avatar
Default 89 dies when clutch released
Whatsup everybody
so this car starts great idles good revs good. Nothing weird with clutch in or in neutral. Goes in reverse fine, accelerates good. soon as i go into first it looses rpms and dies. I can rev to about 2k and ride the clutch and accelerate about 10mph, but at a certain point of release it dies, instantly cuts out. Can get it in 2nd and ride it up to about 15mph.
Have tried two different throttle bodys,injectors,sensors, quadruple checked timing firing order, new fuel pump, grounds & connections... No idea what to try next.
Any ideas? I checked fuel pressure and am getting 45befor filter, 41-48ish after filter
Any ideas at appreciated!
I will be checking compression later today
Old Jun 9, 2018 | 10:02 AM
MTswisher's Avatar
Default Re: 89 dies when clutch released
Im really leaning towards a clog in the fuel system. How much pressure should i have after the filter?
Is there any good way to test pressure fluxuation? The old fuel pump was COVERED in rust..
Old Jun 11, 2018 | 12:22 PM
Evan Owens's Avatar
Map sensor
Old Jun 12, 2018 | 12:30 PM
MTswisher's Avatar
What are the odds of 2 diffetent map sensors running exactly the same? Maybe theyre both bad.. Lol i swapped the intake along with all sensors and car ran exactly the same
Old Jun 12, 2018 | 12:37 PM
Evan Owens's Avatar
Check the plugs, it sounds like they're fouling out. Double check ground at thermostat. Did you get a chance to test sensors to make sure they are in spec? A car will start with bad map/ bad map wiring, but it acts up as load increases. If they are tb mounted sensors, make sure they are securely in the tb and not hanging on by vacuum hose. That will cause issues
Old Jun 12, 2018 | 01:07 PM
Creator's Avatar
Make sure your TPS plug hasn't been swapped with your IACV plug....Just a thought, doubt that's your problem though.
Jibin
Jan 16, 2010 11:52 AM
d15 power
Aug 7, 2009 10:40 PM
TweedZ
Jul 1, 2009 08:13 PM
jxkim89
Mar 3, 2008 04:03 PM
xXx Justin xXx
Jul 6, 2003 12:18 PM
