b18b1 swap completed p28, misfire limp mode?? read codes?
Old Jun 8, 2018 | 02:30 PM
fordmike1980's Avatar
Default b18b1 swap completed p28, misfire limp mode?? read codes?
so fired my swap up today.
i am running a p28, with a p75 basemap from crome
engine light is on
car idles a little high. when you go to rev it, it misfires.
i am using a obd2a to obd1 conversion harness. how do i get the codes off it?
Old Jun 10, 2018 | 06:21 AM
tony_2018's Avatar
Fish Twig
Default Re: b18b1 swap completed p28, misfire limp mode?? read codes?
Same way you would do it for an obd1 car.
Old Jun 10, 2018 | 07:29 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Also why run a p28 with a p75 basemap, why not just get a p75?
Old Jun 10, 2018 | 07:41 AM
tony_2018's Avatar
Fish Twig
some times one thing is easily available than the other.
EXAMPLE: I was lucky enough to find an obd2b p73 USDM ecu for cheap because my cousin lost the obd2a p73 ecu. Seriously.
Old Jun 10, 2018 | 07:50 AM
I tried jumping that blue plug, engine light just stays on solid.
also the reason I'm running a p28 as it was available. Also in case I wanted to go lsv later on. Also because I needed something tuneable for boost in the future.
Plug my obd2a p75 in , car rips. Plug the p28 in with a p75 map, and the car runs but doesn't pull very hard.
Old Jun 10, 2018 | 07:55 AM
tony_2018's Avatar
Fish Twig
basemap bullshit, should've done that test from the get go
Old Jun 10, 2018 | 08:05 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
That’s exactly why I asked about running the right ecu for the engine vs basemapped p28.
Looks like you’ve found your problem!
Diggie
Feb 9, 2019 06:39 AM
Mad-Mike
Jul 7, 2011 06:54 AM
jonman27
11
Jun 8, 2011 02:28 PM
bOOsT-FeIn
May 1, 2011 08:35 PM
G0TB00ST
Apr 6, 2007 10:14 PM
