96 ek, b18b1 swap, crv p.s bracket belt info
Old Jun 7, 2018 | 04:46 PM
fordmike1980's Avatar
Default 96 ek, b18b1 swap, crv p.s bracket belt info
Just got my b18b1 in the car, i used crv ac and ps brackets. wondering if anyone would know which belt i should be using for the p/s. it seems the integra belt is too short. should i be using the crv belt due to the brackets?
Old Jun 7, 2018 | 05:26 PM
tony_2018's Avatar
Fish Twig
Default Re: 96 ek, b18b1 swap, crv p.s bracket belt info
This might require some checking around but you can start with the crv belt and ask the parts store for something of smaller size. They'll help you out.
Old Jun 7, 2018 | 05:47 PM
definitley will do that in the morning. also, on my dx harness i have 2 o2 sensors. one is bank 1 sensor 1, and one is bank 1 sensor 2. the connectors come out of the harness at the same spot as it is a dx harness. the plugs look identical. how do i know which one is the primary one?
Old Jun 7, 2018 | 09:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Your primary O2 sensor has a solid white signal wire in the plug... the secondary O2 sensor has a white/red signal wire.
FeelTheBass
May 15, 2014 08:59 AM
Overlook
Oct 12, 2007 11:30 AM
90civichbsi
Aug 10, 2006 11:45 AM
NY93CivicEx
Mar 27, 2005 07:22 PM
sleepyhamsterlx
Dec 20, 2003 05:41 AM
