swapping a 2001 auto transmission
it would probably more cost prohibitive to change this over considering all the electronics involved with the Engines & Transmissions just go buy you one that's already got a manual in it
For this swap, it would be easier to change out the whole drivetrain/powertrain/computer/etc.
There was a significant enough difference between MT and AT engine/PCM that simply swapping to the 6MT would not be worth the hassle.
Thank you Mad Mike what you are saying is just what i am going to do do i traded off a 51 jeep pu for a 2003 Acura CL type S wreaked car it drove i drove it for a couple of days around the house to make sure it was running good and was a one owner 150,000 miles on the car woman owned it i have the engine and 6MT out on the ground with wiring harness still attached to the engine and the ECU ready to go into the 2001 Acura CL type S i own after careful investigation this is what i have come up with the way to get it to work out right . I just want to Thank you very much for you input it is just what i needed to confirm my findings i hope the years to come your way are the best years you have seen so far in life thank you
drew338
Mar 23, 2008 10:19 AM
