Honda CR-V & Element 2WD & 4WD Element & CR-V
crv sounds like thomas the train and code p0131
Old Jun 6, 2018 | 03:57 PM
fuzzysig's Avatar
Default crv sounds like thomas the train and code p0131
drove my mom's crv to the airport yesterday and on the way there after about 1 hour of driving i heard the blow by from somewhere when i was going uphill under load
then on the way back it progressively got worse and worse and car was hella sluggish by the time i got to my exit. and check engine light came on about 15 minutes before i got home
code p0131
any slight load on the engine would start blowing air from somewhere adn sound like thomas the train.
car has 197000 miles havent had any issues for almost 2 years
Old Jun 7, 2018 | 11:01 AM
UK-Kev's Avatar
Default Re: crv sounds like thomas the train and code p0131
Have you checked your primary O2 sensor and associated wiring
Old Jun 11, 2018 | 10:01 AM
fuzzysig's Avatar
why would i hear air blow by even with bad o2 sensor?
Old Jun 11, 2018 | 12:53 PM
holmesnmanny's Avatar
could be a clogged cat
Old Jun 12, 2018 | 12:15 AM
UK-Kev's Avatar
The error code P0131 relates to the primary O2 sensor – The blowing noise could be a blocked CAT, or if you have been over rough ground you may have damaged the O2 sensor, hence my comment.
Old Jun 12, 2018 | 07:26 PM
fuzzysig's Avatar
it was clogged cat.
does crv have common problem with clogged cats?
my wife's crv cat melted on teh back side
and this one disintegrated on teh front didnt fall apart just disintegrated like termites ate it.
and when i bang it out it was like chimney ash.
o2 sensor code went away
have to order a new cat
what would cause either case?
Old Jun 13, 2018 | 06:25 AM
UK-Kev's Avatar
it was clogged cat.
Sounds like the fuel you are using may have a very high sulphur content, check with your supplier and if this is the case you can purchase additives to counteract this problem.
2stroke1971
Aug 9, 2016 03:33 PM
loki7714
13
Jun 3, 2011 04:01 PM
chad.bawden
Apr 18, 2010 09:45 AM
stefanne3
Oct 19, 2004 02:09 PM
AllMotorBLKITR731
Oct 17, 2001 12:39 PM
