2000 Honda Civic si problems
Old Jun 6, 2018 | 03:00 AM
B16couper831's Avatar
Default 2000 Honda Civic si problems
Just bought myself a 2000 Honda Civic si 178k original miles been having my check engine light on with a few problems the obd2 scanner brings up multiple cylinder misfires random misfires and misfire in cylinder 3 and 2 on top of that idles a little bit when it’s cold and when I rev it when it’s cold in neutral it kinda Boggs out but doesn’t turn off it also makes a little ticking noise when it’s on the. When I hit high rpms it blows smoke it even stained my rear bumper with black residue distributor is brand new changed spark plugs bought original ngk wires freshly tune up up new PCv valve and pcv hose checked my compression all my cylinders are putting out 180 and one of them is 190 still continues to idle and blows smoke when hitting high rpms and continues to misfire on the cylinders someone please help I don’t know what to do now or where to start previous owners said he changed valve cover gasket and grommets and did valve adjustment plus it looks like the head gasket was replaced as well someone please help!!!!
Old Jun 6, 2018 | 10:40 AM
Feriohhh's Avatar
5 Year Member
Default Re: 2000 Honda Civic si problems
that poor car
Old Jun 6, 2018 | 12:19 PM
Shinny's Avatar
Motor has likely been run hard. Could be valve seals, which is not as simple as the cover grommets. So they probably were not changed at the same time.
Old Jun 6, 2018 | 02:32 PM
civic402lx's Avatar
Rebuild it.
use a . or ,
in your paragraph would you.
Old Jun 6, 2018 | 03:48 PM
tony_2018's Avatar
Fish Twig
You would
Old Jun 6, 2018 | 04:22 PM
1999AZhatch's Avatar
Check timing? 🤷 Check fuel pressure. Try a few simple things before giving up and throwing in the towel on the motor. The compression is good after all. The smoke is black not blue, no? So it’s likely burning rich/missing not burning oil. Oh! And triple check your firing order! The recent tune up plus the 2 and 3 cel misfire codes plus the ticking: I bet those wires are mixed up on the distributor. Been there... nice looking car all in all.
Old Jun 7, 2018 | 03:45 AM
White_EG1's Avatar
Replace your spark plugs, plug wires and distributor cap. Sounds like the motor is burning a good amount of oil... I’d do the above and sell it, that si looks like nothing but the previous owners problems.
Rear bumper misaligned, rear lip is half gone, faded paint, **** fender rolling, and no side skirt.
And maybe you should redo the compression test, atleast with a wet test. Cause if it’s burning oil like that it’ll show
Old Jun 8, 2018 | 05:08 AM
SonicC's Avatar
Valve seals probably. Could be multiple issues here...check all the vacuum lines. There's a small one on the bottom of intake manifold plenum, closest to the firewall, that likes to crack or come off and it will give you all kinds of idle issues.
Originally Posted by 1999AZhatch
Check timing? �� Check fuel pressure. Try a few simple things before giving up and throwing in the towel on the motor. The compression is good after all. The smoke is black not blue, no? So it’s likely burning rich/missing not burning oil. Oh! And triple check your firing order! The recent tune up plus the 2 and 3 cel misfire codes plus the ticking: I bet those wires are mixed up on the distributor. Been there... nice looking car all in all.
Also do this.
It would be white smoke if it was burning oil.
Old Jun 8, 2018 | 07:15 AM
White_EG1's Avatar
Where the **** did you get bad valve seals from? He didn’t even mention if it’s blue or white smoke.
And maybe you should research better before you go correcting somebody. BLUE SMOKE IS OIL. A little white smoke on startup would be VALVE STEM SEALS.
But are you blind? Did you not see the picture of the rear bumper covered in black soot? He is burning oil.
Old Jun 8, 2018 | 09:01 AM
mk378's Avatar
To see if it is one bad cylinder or generalized, remove spark plugs and inspect their color. Do a cylinder drop test by disconnecting the fuel injectors one at a time while idling. (Do not disconnect spark wires while running.)
tepasoelrolo
14
Oct 16, 2019 08:17 PM
B2R
Jul 31, 2018 08:53 AM
00ACE00
Mar 23, 2013 06:13 PM
revoapparel
11
Sep 17, 2011 10:23 AM
new2vtec
Honda Civic (2001 - 2005)
Jun 26, 2007 03:58 PM
