cylinder 3 has low compression (125 psi)...the motor should still run correct?
Old Nov 12, 2002 | 06:14 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default cylinder 3 has low compression (125 psi)...the motor should still run correct?
the other cylinders are 180-175...on the 125 psi cylinder, i put a bit of oil and redid the comp check. it checked out at 180. now the engine starts but after maybe 2 seconds or if i try and give it throttle, then it stalls out? if the motor still should run, then what else should i check for? the timing is dead on...it's got spark...it's getting fuel? i'm open for any suggestions. thanks a ton.
Old Nov 13, 2002 | 02:28 PM
QCKGSR's Avatar
Default Re: cylinder 3 has low compression (125 psi)...the motor should still run correct? (not so civic)
get a mechanic
Old Nov 13, 2002 | 02:32 PM
Chiovnidca's Avatar
Have you tried hooking up a fuel presure gauge?
Old Nov 14, 2002 | 10:07 AM
Default Re: cylinder 3 has low compression (QCKGSR)
f'u quickgsr. i can tell your real smart and real new. you need to keep your wise *** comments to your gay self, or make replys like that and let it be known how dumb you are. i don't take my car to any mechanic. and this is not my car i'm fixing anyway. no thanks for your time and waste of space jack'o gsr.
i changed the spark plugs and it works now. that's all i did. and all i wanted to know was if it would run. but i guess i figured it out.
-to the guy, chiovnidca, who mentioned if i checked the fuel...yeah i did check everything. thanks for the time.
[Modified by not so civic, 7:08 PM 11/14/2002]
BIG T
Nov 17, 2007 11:30 PM
subaruwrx88011
Aug 28, 2007 04:23 PM
97grnrs
May 6, 2007 11:15 AM
2000civic-Si
12
Aug 29, 2005 11:47 AM
HybridCoupe
Oct 6, 2002 08:33 PM
