Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
09 pilot grinding noise
Old Jun 4, 2018 | 11:50 AM
09pilotdriven's Avatar
Default 09 pilot grinding noise
i have a 09 pilot that makes a grinding noise while accelerating at about 35 mph for the life of me i cannot find it i have checked the heat shield and its not lose or rubbing on anything im open to ideas if anyone has any
Old Jun 4, 2018 | 09:44 PM
holmesnmanny's Avatar
Default Re: 09 pilot grinding noise
where does it appear to be coming from ? have you pulled the serpentine belt and checked all the pullies for roughness ?
Old Jun 20, 2018 | 11:38 AM
canister's Avatar
5 Year Member
Grinding or rattling? You mentioned heat shield, which produces rattling noise, so I assume you are referring to rattling.
Heat shields on both pre-cats begin rattling when retaining bolts rust through. You either bend heat shields away from the pre-cats, or take a very large clamp and put it around both heat shields and tighten.
Old Jun 25, 2018 | 10:55 AM
thank you for replying yes its hard to describe a noise it does sound a bit like it could be a rattle and i will give the bolts a once over again and see what i can find again i do appreciate the response
alvin enns
Jun 4, 2017 12:49 PM
wxy117
Mar 24, 2008 10:26 PM
makri
Feb 3, 2006 09:03 AM
4thGen4dr
Oct 5, 2004 05:19 PM
