94 DEL SOL ,WHEN WET/RAIN SOLID CEL WONT START FOR 30 MINTS
hi
i have a 94 del sol that wont start (it cranks )when wet or rain conditions , i have a solid cel , fuel pump does not come on , if you let it sit for about 30 mint with the iginition siwtch on magically the cel goes away and it will fire right away , so far i put a new oem main relay , reman pcm , ignition switch , i found a video on youtube that describe the same situation but diferent car
Do you have a crack in the lower part of your windshield that is leaking water on something electronic? Happened in my 90 Accord EX-R when the TCU would get wet and Id have to manually shift an auto to get around.
JesusGLS
Jan 13, 2013 04:59 AM
jdmjim
Jul 28, 2012 08:01 AM
