99 accord ex transmission issue
99 honda accord ex automatic
114k
Runs at high rpm, downshifts on iitsown, stays in 2nd gear, loss of reverse. Next day drives normal at first then does it all over again
also sporadic loss of signal indicator lights
all of the sensors and solenoids in the transmission have been changed - problem remains
ECM in car is 'bk' - swapped out for a 'sb' and car wouldn't start at all
can anyone help with any suggestions?? Much appreciated!
114k
sounds like a textbook internal filter is clogged, when it warms up the filter gets fully clogged with extra debris and stops allowing fluid flow
as mike would say, no flow, no go
needs a rebuild and filter replacement
Chardyll
Feb 8, 2011 12:40 PM
